| Subject |
hissing = vacuum leak... ECU throwin any codes? |
| Posted by |
TeddyZ(SFC) on February 08, 2011 at 3:14 AM |
This message has been viewed 109 times. |
| In Reply To |
car is running rough (please help!) posted by RonDeezy on February 07, 2011 at 11:21 PM |
| Message |
check your vacuum lines for cracks, splits or disconnection. If the problem persists, check your spark plugs, coil packs, ECU and related electrical components. Even if you've replaced the harness, check it. something may have come lose. If it's still screwin around on you, check your injectors and fuel system... if it's STILL acting up, get a 12 guage shotty and point it at the car and in a stern voice proclaim "OK Listen up, if you don't start workin right, i'm going to turn you into Swiss cheese!" j/k =)
| Follow Ups |
Post a Followup |
